Rolling fenders
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/1e6b17af_8a5f_481d_a5d4_dca4c2beb47f_da126d1ca35b92f45ad17765e0d3324f1045585f.jpeg)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/03484dbb_1b7c_4dd2_b81e_0df647a392ba_c2c915ab4b4a145b642878c9205f71a1b339e693.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/e9848aa9_96f1_428c_a443_9cec9a96df4c_9952b4ca18b7ac3a293e6fc6d6781771e8f6e1f5.jpeg)
i bought a fender roller to go lower and so I could turn more without rubbing to bad. So I rolled my fenders (yes it was my first time but I am awake of what to do) and as I did I ran into a problem. There two taps to hold the plastic molding in place and I’m guess it really thick of metal there. It would not roll or pull. I used heat during the process and still didn’t work to bring those two tabs out. Tried so much I kinda messed it up. Idk if this happened to you guys with 430s but I really need help. I would roll more but the more I roll the more noticeable these the taps on the fender look. And yess I even gone to extreme level and cracked paint just to pull that part more out and yet nothing. You can see it more clearly in the full body pic the two tabs that don’t seems to be rolled lol
yeah man positive. My tire was a bit tore up from not being rolling and rubbing and just Turing the littlest bit
oh btw the close up pics are before I lowered more because that’s my goal with stockies
Did you search before you attempted this? I believe this has been covered before and it is known that the tabs will cause a dimpling effect if they are not shaved first.
yeah but no one ever mentioned these tabs. I posted something a while back asking about it cause I was worried about the tabs and most ppl said just go slowly over the tabs or to just cut them off completely. I was not gunna cut them off because well I honestly thought t was not needed. I did start to cut one of them off but rellized it was take a while and I don’t have to much time for it. But thanks for the replies. I’ve came to a conclusion and found new both front fenders. And well I won’t make the same mistake. Probably just rolled the middle right before hitting the weak points. Or if everything goes wel I’ll have someone cut em
I hve no use for these fenders anymore so I kinda wanna see if I could fix em cause wel their trash now. Could I still cut the taps and lip and maybe roll that part again just carefully? Enough to Match the rest.
If you look on IG, there are several quality guys who roll fenders and have done the LS430 before. I know there is on in NC who told me that he shaves the tabs and the lip slightly in order to get a crease-free roll. I would do some research before you try anything else ... lots of good info out there if you search a bit.
thanks guys! I took the fenders to a shop to see what they could do and idk what they didn’t but it does look at bit better not. Dimples are still present but it not quite as noticeable. There is a small amount of distortion when light hits it but overall it t looks okay. Before they were completely **** lol. Not sure what he did actually but I’m sure he did pull but not with a fender roller.
