Gas tank leak
discovered a leak in the tank right by the filler neck,..(a bad spot for salt to lay in there),..I patched it with Permatex patch kit with a brush on a stick,..cause you can't get in there....hoping it holds....anyone else have a leak in this spot?
BUMP! Has anyone successfully patched this area where it holds for awhile? I have been smelling a hint of gasoline from time to time near my old 02LS after fill-up... Blamed it on nearby containers and things until today. Its leaking fuel, looks to be from near filler neck area. I will obviously confirm but assuming it needs a tank. Not one in my state, used or new. No aftermarket apparently? Lexus wants nearly $1,000. At this point, will probably hold out for a used tank + shipping from a totaled southern car, REALLY don't want to scrap a great (getting rusty) car over this. Suggestions?
Physically leaking fuel near or out of tank. 100% positive its not the fuel cap. Does not look to be coming from the filler neck. Rust belt car.
Rust belt owners should keep these numbers/parts handy:
Fuel tank to filler pipe hose (77201-50080 / 77213-50020)
Clip for the LH breather pipe on the filler pipe (2 x 96132-51300)
Inside clip for the RH breather pipe on the filler pipe (90467-12056)
Outside clip for the RH breather pipe on the filler pipe (96132-51100)
Fuel tank cap gasket (77316-16010)
Fuel tank cap (77300-53010)
VALVE ASSY, FUEL TANK OVER FILL CHECK (77390-50020)
GASKET, FUEL TANK OVER FILL CHECK VALVE (77177-33010)
Last edited by StanVanDam; 04-15-24 at 06:36 PM. Reason: Added part #s of clips for filler pipe's breather pipes
