sudden oil leak front passenger side HELP?
I have a pristine 2003 LS 430 with 75k miles. Oil change about a month ago with no issues. Car is perfect. This morning I notice a 2 inch blob of motor oil on my garage floor. The car has never leaked. It appears to be near the very front of the car on the passenger side. Could it be an oil cooler hose or other odd part. Car is not low on oil in any way. I know valve covers can leak but this is a sudden leak over night which never existed before.
I know thoughts?
Thanks,
RKTINC
I know thoughts?
Thanks,
RKTINC
Power steering fluid, maybe?
If the plastic cover under the engine bay is intact, you will have to remove it to see where the leak truly originates. What you found on the floor is just simply what drained through one of the openings.
UPDATE: Seems to be a small drip falling from above hitting the passenger side torsion bar mounting bolt/joint (rear most part of front suspension. plastic cover ends prior to that area so it does not appear to have ran or pooled in the plastic cover. Could it be a passenger side valve cover or an intake manifold gasket? cant see any oil from above with a flash light.
RKT
RKT
Everyone tries to be helpful with forum member’s issues. However, with oil leaks it can be originating from so many different places. Yes, valve covers are common but the only good advice would be to get the car up on a lift, remove the splash cover and clean all oil thoroughly. Drive another 100 miles or so and repeat the getting the car up in the air. Sometimes a good mirror that can be inserted into tight areas can narrow it down. Good luck and let us know how you make out.
RKT
RKT
bradland (04-11-19)
This is the part I hate about having an older car but no biggie....please let us know what you find as we're all in basically the same boat (aging). Pretty obvious from this post it's not mileage, but time, that's gonna get us in small ways. But we'll still roll on past 300k!
yeah back in '16 I said to my indie the LCA bushings are oil filled right would I see it in the driveway and he almost laughed me out of the shop....(he said changing my LCA bushings would probably have no effect whatsoever and wanted to advise me of his opinion before they pressed them out...)
Most likely cause even in very low mileage car is the valve cover gaskets. First thing to do is check to see if the valve cover bolts are loose. Over time the valve cover gasket shrinks and compresses and the bolts can become literally finger loose.
Be careful when tightening the valve cover bolts not to over tighten them as it is very easy to do. Slowly snug them down, as evenly as possible, without over compressing the gasket and oil leak will stop (at least for a while). Eventually as on all engines the valve cover gaskets will need to be replaced.
All aluminum engines require a light touch when it comes to bolts, spark plugs, etc.
