Replace or soften gas pedal?
10th Gear
The ls430 has a pretty stiff pedal. I'd like to make it more sensitive or softer so it doesn't take so much work to use. Is it possible to change the spring out with a softer one, or is there an aftermarket replacement?
My understanding is it's an electronic device, not a linkage to the engine i.e. cable to the throttle body. That device provides information to the vehicles' other systems, not sure if adding tension would work.
Yes, the LS throttle and shifter are both not mechanically connected to the engine/transmission. I dont know how effective adjusting the springs to be less tight would make the pedal more responsive. I would think softening it might make it more herky jerky
Luxor
SC- 1st Gen (1992-2000)
14
11-11-10 12:36 PM
