Adjusting Camber ?
Took my '05 in for alignment and the camber is out of spec on the right rear. Shop said it was not too bad but if I wanted to fix it I would need a lower control arm.
Is this correct? What do I need to adjust it?
Lexus makes three different length control arms to adjust camber. Since I’m assuming yours is out of spec in the negative direction you need a shorter right rear control arm with the length of 441.5 mm
Part # 48730-50080
runs about $200
Part # 48730-50080
runs about $200
I just had my alignment done and the left rear is out by neg 2.0. I have air suspension.
They said it was probably the strut, but it rides fine and isn’t leaking. Do you think I need the LCA too?
Good deal. Very easy install. Keep us updated
If I were to go ahead and replace that arm and then in the future need to replace the air strut, would I need to redo the arm again at that point with a different length? Or is it something that can be adjusted? I’m not sure what length arm I have now. Do they stock the middle one 446.5mm from the factory?
From what I understand the stock length is the middle.
You know what, that is a great question though about the replacement. Im not going to pretend I know about air struts, because the only experience I have with them is through literature. Only have hands on experience with coil sprung 400/430s.
aypues (05-31-19)
I had a similar experience on my 2004 UL.
I had it at a small local tire shop. I didn't realize that my left rear corner was leaking down and the tech didn't know it had air suspension. In their defense They don't usually verify the ride height as coil springs rarely have this problem. After I get the leak fixed I'll take it to the dealer and verify that the ride height in each corner is set correctly before they start playing with alignment adjustments. It's just something you need to be aware of with a suspension that adjusts each corner individually.
Also, if the corner is low and throws off the normal camber it eats a tire quickly. I lost a very nice Dunlop.
For the price I would buy a set of these https://www.shopfigs.com/v3/by-vehic...T/LS430CORMEGA then no worries down the line needing to replace again if you find your alignment out of spec. These are adjustable so can dial in to exact spec.
alexkidd
07-18-17 06:21 AM
The350Girl
11-01-16 03:50 PM
