2003 60K miles $8000?
Kept in heated garage. UL model. Asking $8500. Exterior looks pristine.
Notable maintenance includes:
2018:
Front shock absorber(s) replaced
Rear shock absorber(s) replaced
Strut(s) replaced
Rear brake pads replaced
Rear brake rotor(s) replaced
Rear control arm replaced
2014:
TECH REPLACED THE SERPENTINE BELT
2009:
REPLACED WATER PUMP AND COOLANT LEAKING FROM GASKET
2018:
Strut(s) replaced
2014:
2009:
2014:
CUSTOMER IS HEARING A KLUNKING NOISE COMING FROM THE RT REAR,CAN HEAR OVER ROUGH/BUMPY ROADS,DID HEAR YESTERDAY AND THIS MORNING CK ADVISE ~ ~TECH RECOMMENDS REPLACING THE RIGHT REAR STRUT ASSEMBLY,
2016:
LEFT REAR SHOCK IS BLOWN. RIGHT REAR WAS PREVIOUSLY REPLACED ~ ~50453 REPLACE LEFT REAR SHOCK
REPLACE BOTH FRONT STRUTS
2018:
CONTROL ARM REPLACEMENT REQUIRED TO GET ALIGNMENT INTO SPECS
It looks like all struts have been replaced.
2016:
2018:
If it's nice, I would jump all over it given the low mileage.
That said, it makes no sense that the timing belt was not replaced at the same time as the water pump.
Are you saying that the timing belt was never changed? If that is the case, regardless of condition you might consider some adjustment on price as there will certainly be additional issues/repairs to be done that you are not aware of and now the timing belt.
