Rear vent glass
i can confirm that 01 fits my 04
it's a 1 hr job to remove and replace
after removing the side card you will also remove the electric box that is in front of the plastic sheet(2 10m bolts)
remove the plastic molding that holds up the sun shade(2 push tabs)
remove the top(2 gold nuts)near the quarter glass
remove the outside bottom window trim(tabs)
than remove(1 nut and 1 bolt)from the outside lower part of the door that connects the window rail to the door frame
open the plastic sheet to remove(1 more nut)from the bar connected to the division bar
from there you can pull the window division bar up to slide the quarter window out
reinstall division bar making sure your window is inserted into the division bar making the window line up than bolt every thing back up
before you put the window trim back on make sure the window operates correctly
Shout out to rkw77080 for providing the diagram
ChocosLS430
Hawaii and Guam
08-27-07 01:32 AM
