Local LS430 UL: Good buy?
Hi guys, this is my first post on LS forums as I am from the ISF forums! I have always been a fan of big, wide, luxury cars..especially with ones that are reliable. I have someone local to me who is selling a 2001 LS 430 UL in silver. It isnt in the best of condition both inside and out, so I need your guys' opinions on whether it is worth his asking price.
Here are things that I noticed were wrong:
- it needs both bumpers repainted (no rust that I saw)
- rear passenger seat does not recline but driver passenger is fine
- telescope steering wheel does not work so steering wheel is fixed in the highest position
- vents in center dash are broken/ripped out
- tear in rear driver passenger seat
engine and transmission seem to be running smooth and I no codes when I scanned with the OBD2. when braking the car seems to sway, I thought it could be warped rotors or bad pads but owner assured me they were both changed about 8 months ago and the car isnt their daily driver. The car has 160k miles with a clean title and owner is asking 2500.
vents are missing
rear passenger recline does not work (makes noise when button is pressed but will not move)
rips on the bottom cushion
vents are missing
It sure is rough - many LS 430 models have essentially perfect interiors at that mileage. As far as pricing - if it was nice, it would be worth about $6000 or so with 160,000 miles, so deduct the cost of needed repairs to determine its value.
That’s a hard pass from me.
This would be an interesting clean up to see how good you can get it. Other than the bumpers how is the rest of the paint? You can't always tell everything from pictures but for $2500 it would be a fun project.
On ebay right now you can get the rear seat for around $500 shipped myabe the seller would do a better deal since you'd be buying both.
https://www.ebay.com/itm/2001-2006-L...temCondition=4
You can also find the center vents for $150 shipped you may even find them cheaper if you buy it with the screen and resell it seperately.
https://www.ebay.com/itm/01-03-Lexus...8AAOSwhqBdP407
Get the bumpers painted for what $500? You're going to find more problems than just comsmetic, if the lower control arm bushings haven't been replaced they're past due. If air suspension isn't a big deal for you you should probably factor in a coil spring conversion because the air system will have problems eventually. A lot of interior cleaning later you'd be in $4000 and a lot of time but it could be worth it if you want a PROJECT. Above all you should be very comfortable working on cars, this isn't a car for someone who wants to take it to an indy to fix up.
Ram3n (09-25-19)
vents are missing
vents are missing
Ram3n (09-25-19)
A clean title is most likely the only thing clean in this car. I wonder if the rear seats still work or the rear AC works.? So many things to check that are not cosmetic have to be looked after. If the owner neglected the interior and exterior, what kind of care did the running gear receive? Unless you have unlimited funds, I would pass on this one. There are some great bargains out there yet. Keep looking.
Ram3n (09-25-19)
Happened upon this thread. While the car may be enticing, my concern as mentioned, would be major expenses! Consider all the cash you'll put into trying to make this car decent, take that and the $2500 and find something with minimal issues.
Ram3n (09-25-19)
Nothing wrong with looking for a do-it-yourself project but that's the worst looking LS I've seen here.
When I try to picture the owner who would allow his car to look like that I think of a short, 320 pound guy with severe body odour, breath smelling like cheese and cigarettes, greasy hair and a fake Rolex watch.
If the car looks like that, imagine the maintenance record. When was the last time the oil was changed? Spark plugs?
Probably need several grand and a lot of time to fix the problems that can be seen, so for me I would rather find a $5-6K car that is in better shape and maintenance, even with more miles than this one. Even if offered at $1K, to get the interior cleaned, fixed the broken stuffs like the center vents, and get the maintenance updated (brakes, oil, fluids) so I can drive it without any worry, that will take a good amount of efforts and time.
The original interior of my 98 Land Cruiser with 245K miles looks better than this one.
I would say that is a parts car. Sorry...
vents are missing rear passenger recline does not work (makes noise when button is pressed but will not move) rips on the bottom cushion
kraven9
Wheels and Tires Classifieds
08-25-13 08:38 AM
