LS430 stalling PLEASE HELP
Hello
I've got a 2003 LS430 with 188k on it. LPG converted.
The latest issue is that it suddenly stalls. I think it's getting worse because it stalls every other day.
I'll stop at the traffic lights or to give way and suddenly the car is off.
I was always under the assumption that automatics don't stall.
What do you think is up with it.?
Please help
Thanks
Please help
Thanks
That's right. It stalls when it comes to a stop at the traffic lights. I have noticed that the clock time always resets which I suspect might be an electric problem. I don't know. Just guessing.
There's no lights on the dash. When it stalls, it's totally dead for a second and then regains power in that the nav and radio start working.
Thanks
I'd check the battery cables first. Check for corrosion on the terminals. Make sure the negative cable has solid, corrosion-free attachment to the car body. Ensure the battery is clamped down securely.
If you're stopped and the car is running, does accelerating in reverse cause the car to die?
Hello
Please help
Thanks
Please help
Thanks
Not sure what's going on but hope this stalling issue gets solved soon.
