(Video) 2004 LS430, steering shaft play at firewall
Any idea how to fix this? tried the zip tie trick, it works well enough, but i hate to have to keep getting under there and adding grease to keep it from making squeaking noises. I wonder if it is the firewall bearing, or something in the engine bay that just needs a shim/tightening. play is visually almost imperceptible but you can see it jiggling slightly. it's not the U-joint in the footwell. sound is coming from the firewall.
KKB (09-18-20)
Fojo (10-15-19)
And to add to this, especially keep in mind that the bolt RKW and bradland posted was superseded by Lexus because the original bolt apparently wasn’t up to the task
Fojo (10-15-19)
Noted! Thanks! I'll try replacing these before I move any further . I was also gonna try out the daizen steering rack bushings. As they are only 40 bucks, I figure, why not. These all look like the same bolt part number, is that correct? You don't happen to have the superceded part number do you?
Supersession(s): 0400572147; 4525052340; 9008011555; 9010108070; 9010108118; 9011908926; 90119W0013
https://www.lexuspartsnow.com/parts/...119-08560.html
Fojo (10-19-19)
You’ll love the Daizen bushings. One of the best things I did to my car
Fojo (10-19-19)
Replace steering column with low mileage part and pray. I have spent alot of time on this to no benefit and I think there is a fixed gear in the column its easier to get new column. Good luck and or sell car
Fojo (10-20-19)
Fojo (10-20-19)
