thinking of buying an ls430
Looking to spend around $10k, suggestions on what to look for? I do all my own maintenance on our vehicles. Cutoff for “too high miles” ? Thanks.
For 10 grand you should be able to find a nice 2005 or 2006 with less than 100,000 miles. As far as what to look for, there are scores of useful threads here - search is your friend.
430SLOwner (10-16-19)
Interweb searches yield many LS 430s for sale. Many of these used LS 430s on the interweb have less than 100,000 miles. Less than 75,000 miles is common, and a few even have less than 20,000 miles.
Pros of low mile LS 430s: Less Wear and Tear
Even a car with low mileage can be a beater if it hasn't been cared for properly. However, all else being equal, lower miles mean longer life from most LS 430 components. Many discussions on ClubLexus are around transmission problems after a certain mileage, and oil leaks after so many miles as well as suspension parts. The lower the initial miles on a used LS 430, the longer those parts may last.
Some interweb ads advertise low mileage, even when it seems really not the case. Buy an LS 430 with very low miles, and it may still have low miles a few years down the road. So, repairs required may be less likely to happen than with a higher-mileage LS 430, even with the Lexus reputation for reliability.Some Cons: Cars Like to Be Driven
A problem with older low-mileage LS 430s may be that they haven't been driven regularly. Some parts may get brittle if they're not used regularly, and drive train components should have fluids moving through regularly. So, as attractive as low mile LS 430 may appear, it can also mean repairs, reconditioning, and sometimes even a car which may not run quite right. One looking to acquire an LS 430 may wish to look at multiple LS 430s and maybe even consider comparing low-mileage older LS 430s with higher-mileage newer LS 460s. Maintenance history is always important with any used automobile.
Intraweb searches yield many less than 100,000 mile LS430s and many with quite lower-mileage which may be very attractive.
Main thing to look for is service history. At minimum you are buying a 14 year old vehicle. I think its great you will do your own maintenance but you will want to see the cars history. Create an account on lexus owners site and enter the vin #'s of any car you are considering to obtain the service history. I had an 01 and 06 LS430 both great cars. Make sure timing belt and water pump have been done by now if not budget for that service from asking price. Not many weak points on these cars but by now valve cover gaskets should most likely be done as they leaked on both of my LS430's, the telescopic motor on the steering wheel can go bad as well. If you look at one with the ultra luxury package, the UL air suspension can be a weak point especially at this age as well. If it goes bad many convert to traditional suspension to save the big parts cost.
CA2WALS430 (11-21-19)
I think you can shoot for 80k. I was told that at 80k, absolutely, positively, no chance of causing harm by a tranny drain/fill. I would shoot for a 2006 only, and would be nice to have a Custom Luxury which can be identified by having headlamp washers, and no suspension switches for ride height (that would be an ultra luxury which I would avoid).
Also with $10k you can confidently shop cars listing for $12-$13k. These are 8 cyl cars which in this day and age are not very desirable, which you can use to your advantage. They are very reliable but at this point time is the enemy. The newest cars of this generation is 14 years old. If the car were a kid, it'd be in 9th grade--that's not young by any stretch. I would ask to test drive any potential car for a day, locally, run errands, so you can uncover any issues. Also not a bad idea to run it to a Lexus as if you own it and let them do a multipoint. When it comes back that you need this and need that, it's ammunition for the seller to drop the price. Good luck!
Mattrob (05-02-22)
BPalmer (11-20-19)
The following 3 users liked this post by weldthedif:
The few I've seen so far locally have been over 130k miles and sketchy service records. Good for me I'm in no rush so I can wait for one with good records to come along.
Mattrob (05-02-22)
I've been browsing the market of the entire US over multiple forums, craigslist, major used car sites, FB marketplace, the works.
Personally I think you're looking at $10-$12k OTD for a single-owner, well-maintained LS430 below 100k miles. You'll dip into $9-$10k OTD for around 120k miles, 1-2 owners, well-maintained, w/ timing belt complete. The latter is probably your sweet spot given your budget, and 120k miles is just breaking in for these cars.
My advice - do your research, understand the major maintenance / repair points of the car, determine what colors are IN and OUT, and test drive a few! Also familiarize yourself with looking up service records on the Lexus drivers website.
Edit - the prices I cited above are for 04-06 and I think 01-03 are cheaper so you may want to swing for the latter.
found an 03 w/ 131k for $4900. Looks to NOT have navigation....so what trim level is that? Anyone have carfax available? I'll enter the vin on the lexus website also.
I've been browsing the market of the entire US over multiple forums, craigslist, major used car sites, FB marketplace, the works. ...
![](https://static.cargurus.com/images/forsale/2019/09/22/14/33/2002_lexus_ls_430_rwd-pic-1747340261397680577-1024x768.jpeg)
![](https://static.cargurus.com/images/forsale/2019/09/29/14/47/2002_lexus_ls_430_rwd-pic-1436698720289006895-1024x768.jpeg)
![](https://static.cargurus.com/images/forsale/2019/09/23/13/32/2002_lexus_ls_430_rwd-pic-8479663685239297293-1024x768.jpeg)
wrong coast! I'm in the northeast where everything is more expensive LOL
Also, consider that the NE is a rust belt area, and the potential benefits of purchasing a car from the NW or southern states where there should be almost no rust whatsoever.
