When am I due a second timing belt on my 2004?
I totally love my 2004. I'm wondering now when it's recommended to have my second timing belt change? I'm currently at about 132,000 miles. Any advice?
Margate330 (01-27-20)
Time for belt should be replaced every 80,000 to 100,000 miles.
and when you do it is recommended to replace the timing belt, tensioner, tensioner poly, water pump, and radiator. Will the radiator can be don later but the rest is advisable as you have opens up the front cover of the engine.
when I got mine at 130,000 miles I drove it to 150,000 miles then I did the timing belt job. As pear the mechanic it was worn but still had a bit of life in it.
my next timing belt job is in about 20,000 miles.
Officially I believe it's every 90k and people have surmised the belt itself can easily go double (but potentially something else can go wrong). The 180k is the big one isn't it, where cam seals get done (could be wrong not positive)? And officially Toyota does not do the tensioner at 90k but why not do it....
I have a similar question. I'm in the market for a LS430 that had the timing belt/water pump replaced 6 years ago at 60K miles. Its now at 90K. Should it be replaced again due to the years?
Yes. Years will kill the belts more than mileage will, the pulley/tensioners are what die from miles and they will also kill a belt. Just sitting there though degrades the belt a lot
kclineman
12-07-14 09:49 AM
sayow
12
05-01-14 11:45 AM
