Has Anyone Replaced an Amplifier in LS430?
Old 02-22-20 | 12:07 PM
ariescrown's Avatar
ariescrown
Default Has Anyone Replaced an Amplifier in LS430?
I was told I need a new Amplifier for my 2004 LS430. I won't dare go to a Lexus dealer for their High costs but I need an Amplifier which will take my Mark Levenson Lexus system. If there is anyone familiar with this situation I would appreciate your input. Thank you.
Old 02-22-20 | 02:18 PM
weldthedif's Avatar
weldthedif
what symptoms are you having?
Old 02-22-20 | 03:28 PM
BMW7_LS430's Avatar
BMW7_LS430
No personal experience but this thread may help https://www.clublexus.com/forums/ls-...nd-part-s.html
Old 02-22-20 | 03:49 PM
ariescrown's Avatar
ariescrown
WELDTHEDIF;; The radio does not go on right away sometimes. Sometimes it takes 4 to 5 min. to go on lately even longer.Once it's on and I'm driving I can turn it on and off like it had no problem. Also when I put it on and hear nothing there are no beeps on any commands when I use the screen like putting the air on and off and when I adjust the air speed. You only hear the beep on screen commands when the radio is working. Thanks
Old 02-22-20 | 04:13 PM
Bocatrip's Avatar
Bocatrip
Have you ever had any water intrusion in your trunk area? Have you ever replaced your subwoofer with a non aftermarket speaker? If necessary I’m sure you can find used amps at a bone yard. Naturally be certain to have your issue diagnosed properly.
Old 02-22-20 | 08:46 PM
ariescrown's Avatar
ariescrown
Good point, I'll check for any dampness in trunk and although I never had any speakers replaced It was told to me a couple of years ago that all my speakers and subwoofers were in bad shape and had to be replaced. Because I could still listen to music reasonable well and mostly listen to talk radio I did not spend all that money to do it and didn't want anyone taking all different areas of my car apart. Could it be that the speakers somehow got worse and are causing this new problem ??
Old 02-22-20 | 09:46 PM
Bocatrip's Avatar
Bocatrip
No. If your speakers are original unless they are failing I do not believe that’s your issue. Check for any trunk dampness near your amp.
Old 02-23-20 | 08:08 AM
JS116's Avatar
JS116
Pretty positive its the amp based off your symptoms. I experienced similar problems and had an audio shop diagnose and say the amp needs to be replaced. Check out ebay and make sure its the correct amplifier model for 04-06 Mark Levinson.
Just Just remember if you replace your faulty amp not it could go bad again in another fews months or year. If you're looking for the most cost effective option..I'd go aftermarket completely for the headunit, amp,sub and speaker as it will serve you better in the long run if something audio wise fails.
Old 02-23-20 | 03:18 PM
Zodiac's Avatar
Zodiac
It happened to me last year. I was driving then suddenly heard a loud pop. Afterward no sound from radio but the navigation voice still worked. Anyway, I got my amp service by some guy from Ebay for $400 and still works. I just tried to look the for the Ebay seller but he isn't listed anymore.
Old 02-24-20 | 10:14 AM
kevin3344's Avatar
kevin3344
Check out these companies, HiTechServ and United Radio (not sure why it's not letting me post the link)
https://www.hitechserv.com
I've used HiTechServ to repair the navigation in our SC430. I haven't used United Radio (yet) but heard they have good reviews.
Old 02-25-20 | 08:27 AM
wnyjazz's Avatar
wnyjazz
I just went thru this. Its discussed at the bottom of page 2.
https://www.clublexus.com/forums/ls-...sn-t-work.html
Old 03-09-20 | 04:50 PM
Poppah's Avatar
Poppah
Will a blown fuse from a aftermarket sub amplifier shut the factory radio and ml Amp?
Old 03-09-20 | 05:01 PM
Poppah's Avatar
Poppah
Old 03-10-20 | 11:40 AM
farelex's Avatar
farelex
10th Gear
check this out https://www.ebay.com/itm/274216592788
kwanye
10-09-18 09:51 PM
arcteryx
Lexus Vehicles Classifieds
04-25-16 05:09 PM
lexusdog
10-31-08 10:49 PM
psidediner
12-14-05 04:26 PM
lexusls430
06-15-03 06:07 AM
