Interested in an LS430 or LS460. Would prior overheating scare you away?
Hi All,
I am a long time GS430 owner who gave it up a few years ago to a family member.
Fast forward to now, and I am looking to potentially add something moderately priced, comfortable and reliable to rack up a lot of 'away from home' miles with over the next 2-4 years. The plan would then be to get it to a good baseline (timing belt, brakes, plugs, hoses, suspension, fluids & tires) and then hope to put another 100k on it with normal maintenance only. It would not be uncommon for me to drive multiple states away for months at a time, and leave it at an airport for a week or two there while I am back in AZ. So, reliability is important. I guess this is sort of middle aged man's 'college car' in terms of practical use? Anyways, a 04-06 LS430 or a 2010-2012 LS460 with 60-120k is on my short list.
I found what appears to be a very nice 100k mile 2004 LS430 with modern lux for $9500 out the door. The Lexus website shows regular dealer maintenance and the vehicle appears to have been garaged and cared for with quality parts. This sounds perfect, save the fact that a few months ago and a couple thousand miles ago the car overheated with a cracked radiator top plate and was towed to the local Lexus dealer. I don't know how much it overheated. Radiator, hoses and thermostat were replaced, but the car was traded shortly there after. From there, it appears to have gone to auction where it was picked up by a Mom & Pop local dealer who now has it for sale.
I normally would not even consider buying something like this (either from a used dealer, or that had overheated). However, the car otherwise seems compelling and I had exactly the same thing happen at about 100k on my 4.3L GS. After replacing the radiator, thermostat, hoses and water pump (they did not do this on the LS), it was dead reliable for another 60k and remains so today.
I'm new to this generation LS. What do you guys think? I appreciate any words of wisdom you all have to share.
Start it, let it sit running for an hour and see if coolant is in the oil or any misfire shows up, if it's clean then it should be fine. The engines are all alum so not as vulnerable as a iron/alum type engine
Hi All,
Also follow Striker223's advice. (He is an ace wrench,)
jmo for me it is not wise to go into something knowing there was a major event, because we already have no idea about the minor ones. But if it's me and say I'm looking at a 2013 S63 AMG and they want $35k for it. I "will" need the vehicle for 1-2 days, AND it will be going to a MB specialist who is going to be inserting cameras into panels, measuring the exterior with a paint depth meter, removing stuff, etc. If the seller says no? Then no dice. Sell your item to someone else who doesn't care about what you're hiding and what's lurking within!
The irony of the scenario in the car business? You could buy a LS430 from dealer a, and drive it to dealer b, and dealer b will do a free multipoint and tell you that they are recommending $6700 worth of work. One could say well then how come dealer a is selling the vehicle at full retail and never mentioned that there is $6700 of work recommended? The question to me is whether or not a multipoint is valid. I don't think so, it's a revenue generator. So the key would be that the co. doing a PPI, has the person paying for it, their best interest in mind. The opposite of such would be buying a house from the realtor whose name is on the sign. They have the seller's interest in mind. That would be pretty stupid for them to collect both sides of the transaction.
Margate330 (02-25-20)
When I first bought my car I took it for some settings adjustments and they claimed my car needed like 7k worth of work, I told them they missed a few things and pointed it out for them and they were shocked. Also shocked when it came back for an alignment and everything was fixed, asked where I took it and I said I did it.
After that my service writer is very direct and no BS with me unlike any other breaks dealer I've dealt with, very nice actually and pleasant to deal with on all levels. He even marked everything as repaired in the system for me with addendums of the parts used. The general service and staff was so good If I don't feel like doing something I will take it there when lazy.
The inspection is decent but they will miss stuff since they will not tug one everything by hand and carefully remove every panel, it's mainly a tactic to get you to buy a new car on an old one like these.
The chain I worked at did "free multi-point inspection" on every service they did- even for a customer with an engine steam clean or a tune up coupon it didn't matter.
They were all gimmicks to get the car up on the air with wheels off to "recommend" a grocery list of "needed" services.
Recommended and needed are two different things depending who is benifiting. lol
True this...
I suspect that the owner decided to sell it mainly because it was past due for it's timing belt service. [Or was that already in the service history?]
If the car was pristine and I was interested in it I would try to get a hold of the previous owner to get his version of what had happened. I think it might be a little over valued right now but then again the market price in AZ is certainly higher than what it is here. Let us know what you end up doing...
I will admit I have not read the other posts for this thread. . We all know how any kind of overheating can have lasting affects on any engine, especially an older engine. My personal preference with a car that was so mass produced is to move on. Why take a chance? Unless the car was gifted to you. Too many other choices out there.
430SLOwner (02-25-20)
Thanks for all your help guys.
I'm in Tucson, and use Dan's Toy Shop for any service I don't want to do. This is the car in question and if I were to make an offer, it would include a PPI there done at my expense to include a compression test. I'd then do whatever is on their list and mine. It has had a claimed timing belt, but frankly I would plan on re-doing it anyways so I don't really care.
What I don't know is what if any long term implications there would be of this overheating. Maybe something melted and got sucked into the coolant passages of the engine, or who knows what else? I have trust issues with these type of dealers, but happen to like the spec on this car. It isn't perfect, but if it were being sold privately I would be be interested. LS430s do seem high priced around here, relative to LS460 offerings anyways. Examples: 2005 LS430 Private Party 2010 LS460 Private Party
I'd rather overpay for the right car than get the wrong one, and have time to be patient with this. That may be the best plan.
