2004 LS430 - Transmission Oil and Spark Plugs; labor charge question
Hello, I have a 2004 LS430 with 100k miles.
Ebay or Amazon
1. Can anyone link to me OEM Toyota /Lexus Spark plugs that are a good price and less likely to be knock offs.
2. Same for Transmission Oil ; OEM Toyota/Lexus. How many bottles will I need??
3. DO I need to worry about the timing belt? There is no noise. If so, any OEM timing Belt kits you folks can link to?
4. If I did #1 and #2, how much should the total labor be at an independent shop?
5. If I did all three, how much would labor be at an independent shop?
Thank you.
Thank you.
Thank you.
Ebay or Amazon
Thank you.
Thank you.
Thank you.
Ebay or Amazon
Thank you.
Thank you.
Thank you.
Ebay or Amazon
Thank you.
Thank you.
Thank you.
I suggest that you do some research here with the search function on transmission, Drain vs flush. Before you decide to do it.
It'll also address the type of fluid to use.
Do you have the records of when/if the timing belt was ever changed?
Familiar with drivers.lexus website?
Also if the water pump was changed at the same time. It should be. And more. Coolant, thermostat, idler pulley, serpentine belt. Again research.
These searches should also help with labor ideas.
Unfortunately, what you're about to do isn't simply black and white.
Timing belt plus water pump (always do it with the belt) is 4.2 hours
Plugs are 1.0 for all 8
Trans and oil change are .3 each unless you drop the trans pan, then it's 1.2 for the trans.
Look up prices for parts on rockauto to get an idea for prices
That's great. I don't know that off the top of my head.
Original Spark plugs are rated for 120K miles. Mine is 2004 and I haven't done them yet. Some people have stretched it way beyond 120K and found OEM plugs to be ok. If you have no problems (and aren't OCD for over-maintenance), you can skip that.
I have seen very rare cases of transmission problems with LS430. If it is shifting fine then any transmission service is optional. I did drain and fill thrice and shifts great but probably would have been fine otherwise too.
You should get thee timing belt and water pump done. (if not done already. Open the hood and check for the existence of sticker/check Lexus service records) Along with tensioner and idler. Cost at dealer can be $1K-$1,500. Indy around $800 +- $200.
I installed this kit
The following 3 users liked this post by BMW7_LS430:
I'm actually surprised it costs that much, by the book it's harder to do the intake manifold than the timing belt. I would charge as above for the job since it's really actually quite easy and the best I've ever done in terms of difficulty......too bad I never see 430s since they don't break lol!
Then I thought I will buy the kit and have it installed by indy. Indy said they don't install customer bought parts and with their parts it was going to be $1750.00 These guy are ex-Lexus and were reasonable when they started. Now they got famous and are even more expensive than Lexus.
I gave up looking around and took it upon myself to go after it DIY. Everything turned out alright but I spent about 20 hours. lol. Final cost was $170 for the kit and $100 for the impact wrench. Learning was priceless.
You seem to be a very honest mechanic. May best things come your way! Hopefully some forum members around your location use your services.
During past holidays local Lexus dealer here had a $1K timing belt special and I thought that was a great deal. Someone on the forum used it and posted here.
Margate330 (03-06-20)
On the timing belt thing, at least back in early 2017, the dealer had $1400 and $1800 (Lexus). The $1400 was the 90k, the $1800 was the 180k. Difference being some idlers and the tensioner. Then I called indies and they were $750 and $900, same thing.
I'm glad I went the indie route because I am convinced not only is their price lower, they do a superior job.
Why?
Because dealers operate under the flat rate system of compensating techs. The name of the game for a tech is to physically be in the dealership for 40 hours, but to get compensated for 70. That's every car, every job. This system is not copacetic with human nature. It leads to scenarios like 7/8 spark plugs being changed, 2.5 quarts of tranny fluid this time, 6 next time,. parts being sold that never make it to the customers' cars, forgetting to return used parts as asked, or even better, we don't do that, and on and on. It's not just Lexus.
Food for thought. I used to bring my BMW to the dealer, and I've been to maybe 14 or so. Maintenance was free for the first 4 years, and always a brand new BMW loaner. There were times that I went in for an oil change, that's it, be it the free one, or the interval one that I paid for. Sometimes it took 3 days. And I had their loaner car. Broken system i.e. flat rate. That job is worthless comp-wise, and gets bumped down. Now maybe BMW is an extreme, because in 2016? I had a loaner car for 4.5 months, and my car was in my garage (Takata). To get a free brand new BMW loaner? You need a pulse of at least 50. lol
edit p.s. Takata should be a Harvard Business School case study. I just got my settlement check this week, after 4 years. I can't imagine what the lead plaintiffs and attorneys made. A TON. AND? The airbag that was installed in late 2016, is no good. It needs to be replaced now. Wonder if that means more lawsuits. Takata showed who were the good guys. Honda and BMW were outstanding, free loaners for all. Toyota, Audi, Mercedes, disgraceful. No loaners keep driving lol Mazda Subaru were in the middle.
Why?
Why?
Why?
They tell me my truck needs it AND FAILS TO REALIZE MINE HAS SIDE AIRBAGS. That automatically means my fronts weren't subject to recall and they only realized this after the moron tech pulled my passenger bag igniter and realized my truck had the advanced bags and was fine. Then he proceeded to put it back together wrong and not reconnect my outmost vent sleeve to the HVAC box and mess up some of my screw heads that are visible in the passenger seat. Keep in mind the truck was brought to them with the BAG ON THE SEAT. I told the service manager to "not let the tech put anything back together and ONLY touch the igniter sitting attached to the bag on my passenger seat so they don't mess up my interior (literally mint. Bought new and is still absolutely perfect down to not even the smallest scratch anywhere on the dash).
Not only was I ignored they messed up those screw heads like I mentioned by using a speed gun with a 8mm hex instead of a #2 screwdriver in the center by hand to avoid scratching the paint on the screws but they set my glovebox down FACE DOWN on the concrete floor.
I was beyond livid and walked right into the service department and told the head service writer to go clear a bay, get me the tools I request (I told him everything needed from memory as I just took it apart and remembered), bring me the tech who did it so I can show him how to properly do his job and to tell the parts department I would be strolling through and picking out some free OE fluids for my inconveniences since they can't do their jobs. Tired to hire me after the whole deal was done to top it off.
I'm still infamous at this dealer to this day.
Sorry for the rant but that whole airbag deal drove me a little crazy due to massive dealer incompetence. I'm glad at least BMW cares enough about grenades in customers faces to provide a car for you to use vs some companies just saying pull the fuze and don't worry about it
Try Chrysler.
It was a joke how they gave out loaners for anyone who wanted one. Some folks had BMW loaners for more than 1.5 years. When I returned mine I saw the internal bill it was $93/day lol almost 13k. Then there was some subtraction making it in the low 9's. The only reason I saw it was I asked for paperwork proving I brought the car back. For anyone who gets a loaner more than 30 days--make sure you go back and rewrite the contract. This was not on my insurance as BMW provided. They still required the vehicle to come back prior to 30 days. Normally, when you rent personally, nobody is going to remind you. You get in an accident suddenly your insurance will say that's not a temporary use auto you had the car more than 30 days. Mercedes Benz had an official statement that death and severe injury may occur, however, no deaths have occurred thus far, therefore loaners are unwarranted. It was in writing. Toyota was pretty bad to its customers too, but as they say, love is blind. We all know why BMW went to that expense--image. They are like Apple.
dang sorry to hear. I saw that I had a new recall on the Carfax phone app, and shortly thereafter the selling BMW dealer called (I didn't do the recall there in 2016). Have not taken it in yet.
Image and caring is a big deal, if a company cares for real it's outstanding beyond belief sometime what they will do for a customer. Not related to cars but I am a self proclaimed fanboy of a firearms company who are insane with their customer service and policy. It's to the point they ruin you for any other brand it's so good, basically if anything displeases you, not necessarily something being wrong or not working, but just if you don't like something they will pay for everything and send a UPS truck to you and go so far as to make you a new gun if it's not something they can perfectly fix. You pay literally nothing and I'm sure if they could legally give a loner they would, they suffice with sending back extras and free products. That's how you get someone to spend 57k on handguns
