2005 ls430 not accelerating normally
Hi,
Have a 2005 Lexus ls430 with about 165,000 miles. Just noticed that when I try to accelerate quickly, the cars rpm rise but the car doesn't want to speed up. Best way to describe it is like I am towing a heavy trailer. I took the mass air flow sensor out and cleaned it with the spray and reinstalled it and still does the same thing. Also seems like the gas mileage has gotten worse.
I have within the past 20k miles replaced:
air filter
spark plugs
y-pipe.
Any help is appreciated. Thanks.
air filter
spark plugs
y-pipe.
Hi,
air filter
spark plugs
y-pipe.
air filter
spark plugs
y-pipe.
OTWbrad (03-26-20)
No trans issues that I’m aware of. No check engine light, codes, or slipping. Car seems to do fine when moderately driving and cruising up to speed. When I do accelerate on the highway, it does try to drop down a gear and accelerate but no power. I will disconnect the battery tomorrow and see how that goes. Thanks
Hi,
air filter
spark plugs
y-pipe.
air filter
spark plugs
y-pipe.
Shine a flashlight into the end of the black tube. At the very top are 2 small parallel wires. They should be spotless to operate correctly. They somehow get contaminated. Use your MAF cleaner spray with the straw. Don't touch the wires with the straw but flood with enough cleaner until the runoff is clear and the wires look bright and shiny. I'm guessing once you do this your car will run much better.
I haven't had time to check the MAF but I did unhook the battery for about 15-20 minutes and nothing has changed. I did recently notice a rattle under the car than i have not been able to find. The new y-pipe that I did install is not OEM.
Ended up spraying the two small parallel wires and the car does drive a lot smoother and have better throttle response. Something still seems to be holding it back. I am think it may be a clogged cat due to the raddleling under the car. Thanks for the advice
