Looking for a little oomph...
Good-day guys,
As per title. I know these posts have been submitted many times over and over, but I think I am after a bit of a different approach to those users.
As embarrassing as this sounds, I would like to gain just a little bit more acceleration out of the LS.. I currently have an 04, and apart from a set of sports mufflers, the car is as stock as it comes.
The intention is to not spend thousands on thousands on a supercharger setup, because I don't condemn them in a car like this, I just want that get up go from the line without the major costs, if that's possible.
I've been thinking about replacing the MAF sensor with a new OEM Denso branded one, as I am not sure on record if this has been replaced in my LS, and I hear it can patch up some throttle response issues if replaced. I am also removing the third catalytic converter and adding an X-pipe to my current exhaust setup this week. I've read the X-pipes can actually decrease performance, is that true? I think it was in regards to the piping diameter.. Please get to me on that.
The last and what will be the most expensive, but not supercharger territory expensive, would be PPE headers. I don't even know where I'd source these first of all, considering I am on Australian shores. I also think there's a lot of labor and work involved in installing these, just from what I've read. The tune as well... If this can close the 0-60 gap ever so slightly, I think I might be satisfied. They also give it a good sound paired with an exhaust.
I scrapped the idea of intake, because I cannot find ANY for the 2004 model, and once again, trouble sourcing these to Australia
Kind regards,
Kind regards,
Assuming your LS is in good working order, no reasonably priced mechanical modification is going make the LS any faster except perhaps a tuner style mod to the engine ECU and not sure those are available for a big barge like the LS.
PPE headers $1200-$1500 + shipping, all4swap ecu reflash $300-$500 + Shipping, mandrel bent exhaust $600-$1800 there is no cheap mods for this car. You want to make your car faster get high performance tires, take weight out of the car, make the suspension better. The biggest way to make any car faster is take driving lessons or go to a track and learn how to drive properly.
RA40 (09-27-20)
I added a K&N air filter er and removed the resonators from the exhaust years ago. Not really sure if it helped performance but I always get 25mpg on the highway when i take long trips. Maybe she breaths a little better I guess. The exhaust sounds a little better on cold starts and when I get on it.
Good-day guys,
Kind regards,
Kind regards,
https://www.clublexus.com/forums/ls-...-coatings.html
https://www.clublexus.com/forums/ls-...d-power-3.html
https://www.youtube.com/watch?v=qbJmpzvUVhg
The following 2 users liked this post by Striker223:
jharris400 (09-28-20),
StanVanDam (09-29-20)
Take the tube off the car and run your clean finger along the inside, it will come out with an ultra fine dust and possibly some oil. It's been proven they allow enough silica in to lead to ring/cylinder damage. Look at the edges of the throttle blade as well
If the K & N scheme offered improvement without fouling MAF sensor with oil residue, then Toyota would have expended extra $$.
The 1990-1994 MAF sensor assemblies are $1000..and are destroyed by cleaning with CRC MAF cleaner..... or K & N filter oil residue.
1995+ MAF sensors are not ruined by
K & N filter oil residue, but it certainly does not increase MAF efficiency or life expectancy.
After the K & N filter oil dissipates into coating the intake tract, then what remains to prevent fine dust particles from making their way past filter media (that requires oil to function) into intake stream ??
Some kind of advertising campaign to overlook this.
The way I look at it, Toyota engineers know what they are doing and knew what they were doing when they designed these cars, which is the reason we are driving 14 to 19 year-old-cars with relatively few issues. In my opinion, there is no good reason to run anything but factory filters.
Rollaboy
20
05-03-11 05:48 AM
Japanimal
10-23-02 04:42 PM
