Cabin Air Filter for Lexus LS430
Old 10-13-20 | 02:33 AM
MikeFoxx's Avatar
MikeFoxx
Honestly doubt it matters what you spend because that’s a ridiculous amount of time in between changing cabin filters anyway. They take less than 5 minutes to change and ur paying to breathe cleaner air... at this point you probably wouldn’t notice the difference without even having a filter.
Old 10-13-20 | 04:58 PM
Kira X's Avatar
Kira X
美少女戦士セーラームーン
CL Folding 10,000
I used a nice aftermarket one back when I first got my LS and it held up pretty well. I currently use the more expensive OEM one because my parts guy hooked me up.
According to one of our parts department managers, the more expensive OEM one is the best but the regular one is fine for most people. The price difference is big at retail if I’m not mistaken.
Old 10-13-20 | 08:23 PM
CSA's Avatar
CSA
Do you happen to have part numbers for both versions if there are two OEM versions?
Old 10-14-20 | 03:33 PM
jrmesaros's Avatar
jrmesaros
There's a lot of good quality filters on Amazon and Rock Auto that fit it just like OEM. I change mine around once a year, I wouldn't sped the extra money on an OEM one. Just make sure you get the carbon ones. Another thing to check when you change the filters is to make sure the intake vents on the outside of the vehicle are free of debris and dirt.
milesdf (11-03-20)
Old 10-14-20 | 07:26 PM
Kira X's Avatar
Kira X
美少女戦士セーラームーン
CL Folding 10,000
Talking
Unfortunately I do not have the part numbers. I’ll see if I can get them. I don’t have the box anymore.
Jabberwock (05-21-21)
Old 10-15-20 | 10:47 PM
aypues's Avatar
aypues
this is what I got
https://www.ebay.com/itm/252978985344
part no 87139-50030
Old 10-16-20 | 05:43 AM
Johnhav430's Avatar
Johnhav430
The funny thing is until my 2007 car, I never owned a car with a cabin filter. My wife's 2011 GM--some have it, some don't, ours has it. I'm curious what's inadequate about a $8 aftermarket Denso 4536103, compared to a $36 list OE 87139-YZZ01 ,that is $22 discount. You often can't get free shipping so it's closer to $28. Almost 3X the cost. Even if you have the money, the point is MB < MC, not a lot, if any, is gained in spending $14-$20 more imho.
With German cars, there are often parts that cost $14, that are IDENTICAL to the one costing $33, where the former is the same part without the mfg. brand and packaging. I find this is never the case with Japanese. The lower price on Japanese, is in fact aftermarket. But sometimes aftermarket is more than good enough...get the $8 filters, and get 4 of them. You've now saved minimum of $56 and set for 4 years. my .02
This is what I use from Rock Auto @ ~ $8
https://www.densoproducts.com/denso-...bin-air-filter
Old 10-16-20 | 05:46 AM
Johnhav430's Avatar
Johnhav430
p.s. maybe I'm wrong, this website claims the $8 filter is in fact OE identical. My point was with Germans it's 100% transparent, here we're taking one source's word. This is what I use from Rock Auto @ ~ $8
Old 11-02-20 | 08:33 AM
YODAONE's Avatar
YODAONE
Default Images of original vs superceding cabin filter
McGrath Lexus parts department provided images of original vs lower cost alternative Cabin Filter.
In comparison, the original filter provides almost twice the number of filtering pleats, or surface area. This equates to longer service intervals.
In operation, decreased back pressure and noise in system.
Original filter P.N. 87139-50030..notice positive foam sealing strips
Lower cost alternative 87139-YZZ01 lacks positive sealing strips
caesosa (11-02-20)
Old 11-02-20 | 09:10 AM
CSA's Avatar
CSA
Originally Posted by aypues
this is what I got
part no 87139-50030
Thanks. I just saw this.
Old 11-17-20 | 09:28 PM
StanVanDam's Avatar
StanVanDam
For reference, here's the Denso First Time Fit 453-1007. It appears to be charcoal treated like the Lexus filters, and seems to be similar to the 87139-YZZ01 in terms of construction and pleats (total surface area). I will probably get the 87139-50030 filters going forward when I run out of my current supply of 453-1007 and 87139-YZZ01. Generally, higher pleats and surface area should equate to higher backpressure and higher noise, but I value the more effective dust/pollen filtering abilities over noise anyway.
Denso First Time Fit 453-1007 filter
Denso First Time Fit 453-1007 box
Old 11-17-20 | 09:48 PM
YODAONE's Avatar
YODAONE
If Denso promotes itself as an OEM (perhaps captive) supplier to Toyota, then it would do well to offer an improved aftermarket part.
Thus far none of their OEM supplier inference equates to equal quality to dealer parts.
Sad.
Old 05-19-21 | 10:01 PM
StanVanDam's Avatar
StanVanDam
Slightly related to the topic of Toyota/Lexus filters vs Denso First Time Fit, I have both the Lexus Engine AIr Filter 17801-50030 and the Denso FTF 143-2085. They are visually exactly identical. Same plastic framing, same code on the framing, material is visually identical, same number and depth of pleats, same thickness of material, same wrinkles at the end pleats, same amount of light transmission.
The only difference is the printing on the side of the end pleats :
End pleat printing
17801-50030 vs 143-2085 top-down compare
The following 2 users liked this post by StanVanDam:
CA2WALS430 (05-21-21), Jabberwock (05-21-21)
Old 05-21-21 | 08:15 PM
CA2WALS430's Avatar
CA2WALS430
I change mine out twice per year, 1 time coming up on June 1st, after 'pollen season' here in the NW. I buy from either oemvehicleparts.com or mylparts.com. $20. As for the part numbers...do we have a choice? I think if Toyota decides to replace the part #, we just have to accept, right?
As on all parts, "OEM" does not mean "Original Part".
@StanVanDam , thanks for that information and pics!
Old 07-25-24 | 01:54 PM
ULbear's Avatar
ULbear
1st Gear
Does anyone have the link for the DENSO air filter?
I found one on rockauto but on the amz reviews for that filter some say it doesn't fit ls430.
Just bought a 2002 430 and Im noticing a smell.
