2004 LS 430 - motorized bar against rear windshield
What is this motorized bar? It started happening recently that bar remains in the up position whenever my 2004 LS 430 is in park or drive, but when I put it in reverse the bar retracts downward and out of view. Otherwise, when I shift to park, this bar remains up. What’s the name of this part and how do I get it to stay down?
filmdarius (12-27-20)
Fuse box in the trunk
Pull the tab and remove the cover.
(Go to 3 minutes 8 seconds and 3 minutes 15 seconds on video) ...
filmdarius (12-28-20)
Also ...
■Rear power sunshade
To raise or lower the rear sunshade, push the button.
1. From front seats
2. From rear seats
■Rear power sunshade operating conditions
The ignition switch must be in the ON position
■Automatic operation
●When the transmission selector lever is shifted into the “R” position while the sunshade is up, the sunshade will be automatically lowered.
●To raise the sunshade again, perform any of the following operations:
•Shift the transmission selector lever in “P” position
•Push the switch again
•Move the transmission selector lever out of “R” position and drive your vehicle over 9 mph (15 km/h)
■Retained accessory power
The rear power sunshade can be operated for approximately 60 seconds after the ignition switch is turned to ACC or LOCK position
1. From front seats
2. From rear seats
OK, I'm embarrassed to admit, but this was the fix right here that 430SLOwner provided: it was a simple button by my gearshifter. Not sure if I hit it by accident, but the problem's solved. Thanks for everybody's input!
lbrck02
ES - 7th Gen (2019-present)
30
02-03-21 05:04 PM
