2006 LS430, 104K miles. Manual says use 5W-30 oil. Dealer says 10W-30. Which to use?
This is what is printed in the ls430 owners manual in Oz. Originally I ran 5w-30 but after paying attention to the manual I swapped to running 10w-40 because where I am we never will see air temps below -5 deg c but easily/regularly see air temps in the mid 40's.
Since making the swap I also find the engine burns less oil since making the change, and is quieter running.
1US quart = 0.946352946 liters
1 Imperial quart = 1.13652297 liters
I'm not aware of a different oil pans. We get our fluids in litres so I buy the 5 litre pack.
I pour in about 4l. Check the stick to see it's above minimum line on the dipstick, run the engine for a minute or so. Stop the engine and then top it off incrementally to the max line on the stick.
There's roughly half a litre (give or take 100ml) left over in the bottle. so it required about 4.5l +/- 0.1 after all is said and done.
I typically keep the leftover for any top ups, if needed, between oil changes
Side note: since renewing the cam cover gaskets I have not needed to do top ups between changes.
