Wookiee sound from engine?
Only replace the clutch, do not replace the original compressor if you can help it. Nothing you buy will work as well as it does
My air suspension (not AC) compressor makes a vaguely similar noise upon a cold start and if you have air suspension, I think it's normal. If you don't have air suspension, then follow advice above to isolate the noise. I would start with what LexRex said above.
Random thought, maybe check your AC refrigerant using a high pressure gauge kit, or at least check for correct bubble activity in the sight glass, in order to ensure that your refrigerant levels are good. Both too little and too much refrigerant can cause some strange noises in the system.
LexRex (03-13-21)
10th Gear
[QUOTE=jt3212;11012188]I do! All of this allows me to point him in the right direction so I'm sure he'll let me know.
Personally, have found it better to; learn everything one can about the possible cause of an issue (like you are); then take to trusted indy and keep quiet allowing trusted indy to
use his own experience and expertise to diagnose without bias of being pointed in any direction. Even if/when 99% sure thinking must be this or that. Indy knows me, likely knows I've researched it before bringing it to him. Appreciates me not telling him how to do his job. And, has saved money, especially when indy finds minor or no real issue to what research may have indicated as possibly quite serious.
However, if I know of something that may generate a symptom which may appear to be a possible issue to the indy but may be a symptom due to an idiosyncrasy of a particular model vehicle, will let the indy know, after indy mentions it, that have learned about an idiosyncrasy for that particular model which generates such a symptom, which he does appreciate.
Not trying to coach anyone. Just sharing my experience.
The following 2 users liked this post by 430SLOwner:
jt3212 (03-14-21),
LS430inDE. (03-14-21)
Hi all, I've searched high and low for an answer as to what this sound it but maybe one of you can say whether it's normal or if something needs attention.
Basically intermittently I will hear what I can best describe as a "Wookiee" sound. It is typically brief but comes and goes, doesn't seem to matter if engine is cold or warm. If I rev the engine during the sound it does seem to go away, but it's tough to say for sure. I was thinking a pulley/bearing but based on how it comes and goes I'm not confident in that.
I keep trying to catch a video of it but like all good noises it doesn't want to cooperate. I managed to catch a quick bit of it in this video, the noise is at the 6 second mark and lasts about a second or so. Any help is appreciated!
Noise from engine
Noise from engine
If you determine it is your AC Compressor clutch bearing....
See:
https://www.clublexus.com/forums/ls-...lutch-p-n.html
jt3212 (03-14-21)
Batavia
12-03-20 12:37 AM
