Fixing a Broken Radiator Overflow Nipple
OK, I just completed my TB and WP service and like an idiot I thought I needed to remove the overflow hose from the radiator (you do not, it comes out in one assembly with radiators and the fans) and when doing so I broke it off the radiator (don't do this). After much deliberation and research, I decided instead of throwing away an otherwise serviceable radiator, I decided to repair it with High Temp epoxy. See pics of the process I took, hope this helps someone else in this situation. I will report back over time if it hold up
The following 3 users liked this post by Viper6:
Interesting solution and maybe worth the effort. If me I would use a loan-a-tool program from local auto parts store and do an o overnight pressure test to confirm the repair. As some plastics don't do well with expoxy. The overflow nipple also failed on my 2004 LS430. Apparently the typical fail point on these radiators.
Better to discover the weak spot in your garage rather than on a road trip. If it holds great! If not, replacing the radiator is cake compared to the TB and WP.l work you did. Also I used a Denso from Rockauto with the tow package option and a larger capacity that has been perfect for 5+ years. It was also less expensive than non-towing version, oddly. Couldn't justify paying about 3 times as much for dealer OE part so went with quality aftermarket. Others would only use OE, to each his own.
Could this work on a power steering reservoir? I already replaced the return line hose/vane pump o-ring, but it still leaks occasionally, so there could be a hairline crack in the reservoir
Good idea, but with the a couple of coats of the product it has already brought the OD to max size and still use the original overflow tank hose, we'll see if it holds.
Honestly, it was a fun C19 challenge... realizing now form your post that a good quality radiator is maybe $100 shipped, it would have been less expensive to replace after factoring the value of my time... but this is more fun (queue MacGuyver theme song!) and keeps some junk out of the landfill at least!
V6
infojunky (03-29-21)
pmpdaddyt
Performance & Maintenance
11-01-08 04:26 PM
