Need to correct rear toe in (LS on Airlift 3P)
Do I need to purchase all three lower arms (traction, toe, camber)? or can I skip the camber arms? I don't want any more camber in the rear, if anything I'd want a degree less to match the front (very content with natural camber). Can I just get the 2 arms to correct the toe in? thanks!
You shouldn't need to get the camber arm since the traction arm should center the wheel back to the original location and keep camber in spec. Do you have too much toe in or toe out currently? Reason I ask is I believe you have to lower the subframe to get the cam bolt out for the toe arm and maybe the adjustable traction arm will also allow you to keep the original toe arm. Someone else with more knowledge on lowering these cars can confirm what is needed.
