Check VSC and track off alert
Old 05-13-21 | 04:45 AM
ONashir's Avatar
ONashir
Default Check VSC and track off alert
Mine just came On check engine -Track off
check vsc then after 2 days it went out
Old 05-13-21 | 09:28 AM
bradland's Avatar
bradland
Have your battery checked.
Old 05-14-21 | 12:29 AM
WILLYumD's Avatar
WILLYumD
VSC and traction control light will come on with the check engine light for some error codes. Feels like liability management "Hey, your car is not performing normally, we can't guarantee your traction control will perform normally, either."
Get your codes read.
Old 05-29-21 | 03:40 PM
2005GX's Avatar
2005GX
10th Gear
I know it's only been a couple weeks but did you get the codes read?
If so, can you share what they were and if repaired, what did you do to correct this?
Thanks, as I'm in the same situation and appreciate any help.
Old 05-30-21 | 08:02 PM
Thedeous25's Avatar
Thedeous25
4th Gear
Default Beep Beep Beep Beep Beep
I reset the vsc because it was hopefully fixed i guess but ever since the traction control alarm(?) comes on what did i do?
Old 06-02-21 | 06:05 PM
StanVanDam's Avatar
StanVanDam
What you need to do is to get an OBD2 code reader, most preferred is Toyota Techstream, next most preferred is a code reader that is specialized for Asian cars. These will let you read the codes from the VSC system as well as the generic OBD2 codes.
Once you obtain the diagnostic trouble codes (DTCs) for all subsystems (ECM, ABS/VSC/TRAC, etc), then you can determine the cause of the problem(s) and follow the troubleshooting steps for each code.
Most causes of a check engine light (CEL) will put throw a Check VSC message and put the VSC/ABS system in impaired functionality, as the VSC/TRAC computer needs perfect engine operation and control in order to operate the VSC/TRAC system.
wnyjazz (06-07-21)
Old 08-29-21 | 12:52 PM
ONashir's Avatar
ONashir
Default check-vsc-and-trac
One of the hoes for air intake was not snapped in all the way it has A clap on
Old 09-23-21 | 06:12 PM
ONashir's Avatar
ONashir
Default Code translation
All the codes for Check engine - vsc - TRAC OFF
Old 09-23-21 | 06:16 PM
StanVanDam's Avatar
StanVanDam
Code translations are sometimes wrong, especially if the software isn't specific to Lexus/Toyota/JDM/Japanese. But looks like your transmission is messed up. The easiest thing you can check yourself is fluid levels. Search these forums for how to do that, the procedure is different for 2000-2003 vs 2004-2006. If you can't figure it out, take it to a professional.
Old 09-23-21 | 06:19 PM
ONashir's Avatar
ONashir
Default Found one
$1030
waqas300
08-24-19 12:12 PM
snayger
04-22-13 08:33 PM
Laozy
03-04-13 05:27 AM
gritty
03-29-11 09:34 PM
MD350
ES - 5th Gen (2007-2012)
07-20-08 05:10 PM
