2004 LS430 how to turn VSC off?
In the 2004-2006 models the "Trac Off" button does not disable VSC (stability control) like it did in previous models. Holding it for more than 3 seconds does not shut it off either, like it does in the newer models. Is there anyway to properly shut it off? I tried looking at older posts but old news. Checking to see if anyone has found a solution.
https://minkara.carview.co.jp/smart/...1786/note.aspx
You may need to use Google if your browser doesn't translate it from Japanese for you.
To re-enable VSC/TRC you need to switch it back on with the switch, and then turn off the car before restarting it.
