Stock Swaybar Links able to holdup to UltraRacing?
My rear sway bar end links went bad and I got OEM replacements, but also decided to upgrade the 14mm stock sway bar to the 19mm UltraRacing rear sway bar. But using the OEM sway bar end links, will they hold up to the stiffer sway bar or do I need to find upgraded sway bar links as well?
BTC89LS400 (08-29-21)
Yes, you won't have any issues. I'm running that rear bar with either stock links or Moog links (I can't remember) and no issues in the three years that I've had that setup.
A question for those who own Ultra racing rear sway bar. Is it worth to upgrade? I'm on OEM soft springs and would like to add more stability when cornering.
Won't it worsen the ride quality on uneven roads with lots of cracks, etc?
Thanks, Romanova. I'm not expecting miracles, but for example, I have a set of sport shocks and struts and I surely say that they were cornering much better that non sport version, but harshier on cracks and potholes.
And I've read that the combo of standard suspension + 19mm rear sway bar might be a nice comfortable combo.
