Drivers side fuse issue
I read a forum posted back in 2012 and no one responded to it having answers but here are my issues
my seat memory for drivers seat does not work(yes I have tried calibrating it but it doesn’t make it work nor does it beep)
my drivers side window up and down button works but does not go down in auto mode on any of the windows( but at each individual window they can go up and down in auto mode)
my seatbelt adjuster does not work at the driver side but my passenger does
my steering tilt does not work but the telescopic works
I’m assuming most of my issues are due to fuses
any answers would be so helpful
thanks
thanks
Sounds more like your drivers door has a grounding problem. Check the connectors for corrosion and test that the door is fully grounded with a multimeter.
It only takes a slight drop in voltage for many of these CANBUS controlled items to malfunction and a poor ground is pretty common in many cars.
The steering tilt is almost certainly because the motor has died. It's a common fault on these now that they are getting older.
mx22o
GX - 1st Gen (2003-2009)
12-11-07 07:53 AM
