Backup Camera
I did similar unit / camera combo. I made a post about running the camera wires in the trunk. What pin for the reverse power ON and the ground lug was close in trunk as well.
But basically pop passenter trim along door sill, remove back seat and install the antenna / Adapter cabling and wire in the trunk. Not challenging, just need to unbolt/install/reassemble.
I also presume you'll need a beatsonic adapter to make the headunit work. But its simple to crimp and install the beatsonic. Woirks perfect with our older cars!
GregoryNP
08-16-14 06:25 PM
