Wheel Offset ?
Wheel Offset ?
I have a ? I want to put some wheels off of a 2003 SC 430 on my 2006 LS430 all the specs are the same except the offset, on the SC430 the offset is between 34-45mm on the LS430 it is between 30-45 is that enough difference to not fit.
Your LS has big brake calipers and this presents a spoke clearance issue. The OEM SC wheels will not fit unless a 15mm spacer is used, the back is fine. With the front spaced 15mm outward the rear looks pretty sunken so you may consider adding some 15-20mm spacers in the rear for visual continuity. The wheels you consider buying should be BBK or high disk fitments.
Additional info in the 3-LS FAQ here:
https://www.clublexus.com/forums/ls-...iy-thread.html
bjchilds1 (02-03-22)
Are they these wheels?
this thread says you'll need spacers
https://www.clublexus.com/forums/ls-...l-spacers.html
