Air Tank Install?
Air Tank Install?
Hey all, I have a 2007 Toyota Crown Majesta, as far as I'm aware the air suspension system is the same in the LS430 as it is in my car. I know that with the ASC680 controller you are able to bypass the stock settings to slam it almost to the ground and also raise it a good amount as well. I am wondering whether or not it is possible to install an air tank to work with the factory suspension, that way it doesn't have to go through multiple duty cycles in order to air up and down to your desired height, as well as speed up the process of the airing up and down as it normally takes a good 5 mins to air down to the lowest height. Has anybody got any information regarding this? I'd love to do it to my car if it is possible. Thanks
You might try hitting up the GX470 board. I had an 04' roughly 6 years ago, and did an air suspension delete, and it has a small reserve tank built into the system from the factory.
Not sure if the LS430s have a tank or not. I haven't torn I to my UL yet to see if there is one or not.... Maybe someone else can chime in...
if there is a built in air tank, i haven't been able to find it. and I'm guessing if it did/does have one it should be capable of airing up and down at a reasonably faster pace than it is currently.
JDMUCF21
06-23-21 11:11 PM
