Wheels and tires.
Hey guys. New ls430 owner and new car over a 1990 model ever so wanting to know if I can put 245/55/20's on my stock ls430?
Bought a set with the tires on them and there basically new so dont wanna buy a set unless I have to.
IMPALA8014 (04-13-22)
Thank you! Guess I'll have to drop the cheap route and get a new set. Any one got a pic of a 06 with 20" chrome snowflakes on stock the ls430 suspension?
Have you test fit these wheels? Our cars have big front calipers and you may need a spacer to get them to fit.
Also there is a 20" wheel picture thread sticky where you might find something similar to what you have
https://www.clublexus.com/forums/ls-...our-ls430.html
I'm running 245/40/20s and they do rub on stock suspension in the front over big speedbumps/potholes, that's probably bc I run 15mm spacers due to the large brake calipers. the rear wheels don't need spacers bc the calipers are smaller.
wheel size I would not go bigger than what I'm running now, I def regret not getting slim profile tires
yes tested new rims and going with a 20mm spacer to clear calipers. Rims came off a cbrysler 300c and bolt pattern is good just offset is in the way in front.
you will probably be fine but will rub a little bit. Would recommend thinner tires. and don't use spacers on the rears at all, mine rub a LOT when I had spacers on. its unnecessary
gs4to4
Wheels and Tires Classifieds
06-19-06 01:47 PM
