Stuff to fit front Mustang wheels !!
I have my longer studs and the wheel nuts to go with them for when the 10mm spacers show up and I can fit the Mustang front wheels to match the rears already on the car !!
It was just touching on the plastic trim screw , the second one up , you can see the screw in the picture .
I will just bend the lip back a tiny bit and the screw can go back in , I will also trim about 2mm off the lip about a 1/3 around at the top as at severe suspension compression it just touches a tiny bit .
So yes it does just touch but only a tiny bit , with those screws removed I might hear a scrape once a trip and once I trim the upper lip it won't scape at all .
