Help Code p0011
Just do a Google search for the code, eg. "P0001 Lexus"
P0001 is a diagnostic trouble code (DTC) for "Fuel Volume Regulator Control Circuit/Open"
https://obd2-elm327.com/p0001-obd2-code-trouble-failure
P0011 LEXUS Code - Camshaft Position 'A' Timing Over-Advanced or System Performance Bank 1
Possible causes:
-Low or Dirty Engine Oil
-Variable Valve Timing (VVT) circuit is open or shorted
-Oil Control Valve (OCV) circuit is open or shorted
-Faulty variable valve timing (VVT) Faulty oil control valve (OCV)
-Damaged Engine Control Module (ECM)
https://www.autocodes.com/p0011_lexus.html
Possible causes:
