HELP! Rear Differential
10th Gear
I have a 06 rear differential is going bad, making clicking noise when driving, shop said i needed to replace the diff, so any ideas where i could get one? I’m also open to get a welded diff or lsd. Currently searching for a diff on ebay but i wanna hear other knowledge tips before buying. Thanks in advance!
You could give this guy a try. Looks like he may have one or more from the look of the cars in his yard.
Sorry not letting post facebook link
10th Gear
Love Time > Lexus LS430 owners CLUB
Lexus ls430 parts.
He has several that he is selling out for parts.
Someone just bought two mirror assemblies that I was interested in for the color.
Lexus ls430 parts.
Check to make sure it's not your axles broken axles click not rear ends. The rear end will sound like a really bad loud power steering pump whine with some metallic banging sounds.
You can also swap in sc300/400/gs diff as well with a 3.92, 4.0 gear ratio etc you just need to swap the pinion flange between the rear ends. Oh also for 04-06 you need 01-03 uneven length axles other than that it bolts right up.
nvwls (09-21-22)
10th Gear
Are you sure it's not coming from the cups right next to the diff I am 99% it's not the differential. Rear ends in general don't making clicking noises it's either loud whining like a power steering pump from hell which is usually bearings, or they will clunk and clatter from teeth being stripped off or the physical gears being broke.
10th Gear
couldn't upload it on here
it is the differential right?
8052JZ
Performance & Maintenance
25
06-10-14 11:00 AM
