What life expectancy should one expect out of OEM replacement Air Struts?
Air Struts are such a controversial topic here. What life expectancy should one expect out of OEM replacement Air Struts? Would buying a car with 65k miles on new replacements be a bad idea?
Are you saying that the air struts were replaced 65k miles ago? The life of any car suspension part depends, partially on how the car was driven, the condition of the roads and how the rest of the suspension was/is maintained. To give you a very broad answer, air struts can last 60-150k, maybe more maybe less. Your question may seem simple, but the answer depends on so many factors. You do have the option to convert to standard, non air struts for a low price compared to air shocks.
This would be a car I was thinking of buying where fronts were done at 40k miles, rear right, compressor done at 50k and the car has 104k on it. From Texas, elderly couple, one owner. I need the air suspension for medical reasons. Yup and I could always switch over to regular but I dont know how the ride will be. Thanks!
Always get a prepurchase mechanical inspection on a used car. The more documentation you can find regarding maintenance, the better to make uninformed choice. Go to drivers.lexus website and enter the VIN number for dealer recorded work. Something to consider is the "sticky dash" that can occur on older LS models. If the work was done, great.
Rats Im in the wrong forum, yes for a 430. But Im sure they are the same. Yea so thats weird too replaced at 10k, kinda like the one Im looking at.
Drivers.lexus is amazing I can see the whole history of the car. The air struts on my 460 were kinda stiff but the ride height wasnt working and they may have been stuck in sport mode.
I'd go the Arnott struts if they failed although they dont have dampening adjustment Iv heard. Quick Reply
Thanks, yea thats me. So I was thinking of a Buick Lacrosse but they are apparently not the Buicks of old, firmer. But I was also thinking of a 2010-11 Lincoln Town car. Would that be quite enough or like the Buick, seems maybe better? The Lexus might be quieter? My real problem is shock and vibration, steering wheel, seat floor.
I test drove a 2009 es350 and got a bad spike as it was vibrating. But I also noticed it was to hard on the bumps, shock just transferred to cabin. Hybrid would be nice but those batteries are expensive and the 300h most likely would have similar ride to the es350.
Lacrosse would be quieter than TC? Town Car has rear air shocks, but Lacrosse has more modern suspension. Which would be better?
Cool thanks I really needed input. I'v heard people complain the Lacrosse isnt the boat Buick used to be and the ride is a bit firmer. I could only afford a 2012-2015 maybe. They have active noise canceling which might or might not be good for tinnitus.
The LTC is likely going to be softer than the Lacrosse overall in terms of transferred shocks but the engine is not as isolated, try both?
The thing about the Town Car is its body on frame, being body on frame it might be more isolated from the type of vibrations that bother you. Its the only somewhat modern car you can buy that is BOF.
This poor guy has been posting about car vibrations since July of 2022. It seems that more responses and opinions aren't helping and possibly making things more confusing. I sincerely hope he finds what he needs soon. In the spirit of helping, low profile tires are going to transmit more vibrations. Many luxury cars come with wheel options from 18"-20", look for 18". Then research tires on tire rack for the best tire to suit your needs.
