Rear door shades
Get a new door? I think you need to do a lot of stuff, there are two curtains, one vertically and one horizontally for the tiny triangle window. Just what I can think of: door panels that has the cut out for the curtains, the roller curtain mechanism, not sure what else is different internally to fit all that stuff. The tiny curtain I believe rolls into the triangle glass pillar, then there are the mounts for the hooks on the corner of the door and the top of the door.
So I recently found a UL at an LKQ and pulled the rear door panels for this upgrade (and the UL glass). The shade resides in the top 1/3rd of the door panel. Idk if you can swap the piece into the non-UL panel or not. Haven't gotten around to do it yet. You also need to pull the inside window trim b/c it has two tabs which the sun-shade rests when deployed. Both the door panel, and inside window trim are pretty easy to pull. Maybe 15 min per side. The rear UL glass is a little harder as you have to remove the inside rails to pull the glass out.
Not impossible but very unlikely. The shades retracts into the door and hooks unto the windows. You either need a new or complete interior door trim from a UL. Then, realize the interior colors and leather trim materials are different for the UL. The door cards also have cut-outs for features that are unique to the UL. The wiring harnesses may be different.
It just seems a lot of time, effort and expense. That said, it's up to you.
