2014 Lexus LS 460 f sport no power,no dash lights, won't start
1st Gear
My car isn't starting it's not the battery I've already tried that bought a brand new battery nothing I bought a starter relay and replaced it still nothing no lights come on dash car doesn't start I changed the spark plugs what else could it be I tried changing the battery in my key fob still nothing can't even lock my car what's the issue idk what else to do
If you don't have any lights, why would you change spark plugs?! I would start with fuses and battery cables.
The following 2 users liked this post by Anfanger:
dlbuckls10 (02-28-23),
THE_CEO (03-01-23)
Check for voltage at the fuse block with the starter relay. If there's no voltage coming into the fuse block, It's likely somewhere between there and the battery. This is a complex car, as most modern cars are. I'm afraid you've got an issue that can't be solved on the forum. Can you plug in a diagnostic tool into OBD2 port and look for codes?
BigJarsh91
RX - 1st Gen (1999-2003)
02-24-21 07:27 PM
