LS460 P0353 and traction light on
2nd gear
After doing both valve cover gaskets, oil pump seals and spark plugs tube seals my 2008 LS460 cracked fine but after a few minutes threw a P0353 which is ignition coil c.
Here's what I observed:
1. After pulling the ECU fuses and disconnecting the neg terminal car starts fine and about 2 -4 seconds in throws the code and starts to miss. Traction Control light also came on with this problem (not sure of the two are related)
2. When I clear the check engine light car runs fine for about 2 to 4 seconds then throws the code again.
Here's what I tried so far:
1. Swapping the coil for cylinder 5 results in the same code. So I believe the coil is good.
2. Swapping the spark plug with cylinder 5 results in the same code. So I believe the plug is good.
3. Cleaning the connector results in the same code.
Is there a way to test the connector? Or are there any suggestions. I did a search among the forums but didn't quite find a situation like this. Apologies if I missed it. I will remove thread if redundant.
Thanks!
Thanks!
Yes, there is a procedure in the manufacture manual, however, it is long...
1st pin to the body ground should have 11-14V, 4th pin to the body ground should resistance below 1Ohm. 2nd and 3rd pins connected directly to the ECU and should have very specific resistance.
2nd gear
Thank you this is a good start. I was able to find the manual and the procedure. Will give that a try this week and see where I come up!
Thanks!
Thanks!
