Any way to get the front lower rearward control arm out of ball joint w/out damaging
Hi all - so I am in the process of replacing inner and outer tie rods on my 2011 AWD and because I ordered the FIGS kit it came with brand new power ball joints as well. I would really like to replace these while I'm at it but I don't have new lower control arms yet...so my question is does anyone know how I can get the lower control arm out of the ball joint without screwing it up?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Also I cannot (tried the special inner tie rod tool, tried heat, tried a hammer, and a wrench) for the life of me get the passenger side inner tie rod loose... Anyone have any advice as to how I can get this off??
Thanks for the suggestions!!
It shouldn't be that hard, especially, with a special tie rod tool. Did it look like somebody other than the manufacturer was there before? Are you trying to turn it in counter clockwise direction when facing it? You need to be careful around the steering rack, it is electronic after all.
So at this point I am just going to start looking for a steering rack and pinion as my current one has to be f***ed. Spent most of the day trying to get this stupid tie rod out and the damn thing won't move. Impact, heat, sledge, everything. Kinda looks like my rack may not be perfectly straight and see a bit of fluid puddles in the rack housing. Almost actually looks like maybe the tie rod that's in there was cross threaded?? I don't know. I just know I am out of ideas and this totally sucks.
There is a sleeve that's built into the knuckle. Sometimes the tire rod gets stuck in the sleeve and when you try to get it off the sleeve move with the ball joint. I've had this happen to me and could not understand why it would not bulge until I took a closer look. Even though you can't really get a ball joint puller in the knuckle straight I got it in there enough but you have to make sure at least one of the claws is gripping the bottom of the sleeve so it doesn't move. This will most likely destroy the threads on the tie rod but if your putting new ones on it should not matter.
Thank you!! I finally got it off and of course by applying what I learned from the passenger side the driver's side was a piece of cake. I used one of those clawfoot kinda inner tie rod tools that you just hook a breaker bar into and that allowed me to finally get it clamped down in the right place to apply the necessary force. I really appreciate all the help everyone!
Now if I can just figure out what this terrible noise is that is a new development - I think I'll be in pretty good shape! Lol...
https://www.clublexus.com/forums/ls-...l#post11467337
Alexusc300
SC- 1st Gen (1992-2000)
06-06-15 03:09 PM
CManolo
12-05-14 03:35 PM
