2013 LS Power steering light on and loss of Power steering
2nd gear
Tow or drive to LExus dealer? any ideas what loss of this will cost? Just had the valley pan done. $$$ Thx
Lots of members recommend going to an indy shop that works on Japanese cars. Dealers have high overhead, higher prices and not always the best techs and knowledge. The steering is electric/electronic. New or used parts. $2-3k total depending on awd or rwd. An indy should cost less.
The following 3 users liked this post by swfla:
I assume you checked the fuse?
If the unit is toast it will likely one of these, might be helpful if you get an estimate.
swfla (06-05-23)
Service manual lists the following as culprits:
- The power steering ECU connectors are disconnected from the power steering ECU.
- There is a malfunction in the power steering ECU internal circuit.
- There is an open in the harness between the combination meter and power steering ECU.
