Transmission BS
Transmission BS
Hello everybody!
I have a 2007 LS 460 with about 150,000 miles. Recently I was told I would need a complete rebuild on my transmission and Lexus said that they didn’t have the room, and furthermore, I didn’t want to pay the price for dealership work. Long story short I went to a highly recommended shop but I keep having to go back because of two things. One, the car clunks into reverse, and two, has some pretty rough shifts where the rpms will spike up and I will immediately let off the gas. Any ideas on what it could be?? Let me know here or email me at jchsurfs@icloud.com with your opinion. 😊
Clunking could be drive shaft related at your mileage as well as trans. I've seen many posts here about flywheel issues and torque converter issues that give these symptoms. What did the shop do to fix your transmission?
Nospinzone (07-24-23)
juan2004 (07-24-23)
Did the shop do the transmission ECU relearn procedure? You need to reset the TCU in order for it to relearn the correct shift points. You have to reset it then immediately drive, shifting through all eight gears, then come to a complete stop. You have to do that repeatedly for 5-10 min until the TCU has relearned the correct shift points.
Suggest you ask the shop if they did the ECU relearn. Being they were highly recommended, they probably did. What has the shop told you about the issues you're having? Are you done dealing with them? We've given you a few suggestions. It seems to boil down to the shop willing and able to remedy the issues if you trust them or move on to get another opinion from a different shop.
You guys are all totally right about getting another shops opinion but I’m really worried about affordability on this one because I already paid $3600 to have everything redone and I don’t know how much more I can shell out for this transmission. But it seems like I’m gonna have to go to a different shop.
You're kinda in a bad position now, most legit shops won't want to touch it because someone else has already taken it apart, the shops that will work on it will have a bullet proof explanation for anything they do that doesn't get you the results you are looking for.
Did you take it to the shop that gave you a quote in this post?
https://www.clublexus.com/forums/ls-...nsmission.html
I am on vacation right now and whenever I ask them what they did, they said that they replaced some solenoids EDC I believe they also said they replaced the torque converter but other than that they won’t tell me what they did besides all the rubber seals
swfla (07-27-23)
