Keys not working
#31
On page 867, make sure the “smart access system with push button start” is ON.
#34
Great addition to my Fsport gives it the right amount of rumble without scarification of comfort or class
#35
Spoke to Dealers on the phone and they want $1100 to “reseed” both original key fobs, does anyone know the procedure? Maybe I can try it - btw I changed the battery once more with a Duracell and still no results
Also checked out all fuses from hood to under steering wheel and as well inside the trunk. All looks good - could it be the battery? I recently had it replaced 6 months ago
#36
Alternatively you can just order a "3rd" new key from them and have them program it to the car for under $500, if you are convinced that the keys are the problem.
#37
Thanks for quick response- I do not believe the keys are a problem..why would both keys give out same time? I believe that both keys are asleep..if that’s a thing. One key has always been in storage and one key has always been in use - is there a reinitialize process? Because it’s happened before with my Toyota Camry when I changed out the battery I had to unlock and lock the car with key and at ignition switch also
#38
Techstream can do it. But Ebay purchased TS are often incomplete and may not be capable.
There are locksmiths who do this as well. Worth a couple of calls.
FWIW, the dealer may be charging $550 per key as they have to do twice the work. Brutal price though.
Using a multimeter to check coin battery voltage may be enlightening.
#39
I've used 4 different versions of the cheap techstreams available on ebay / amazon. The key section in techstream functions fine on them.
If you decided to change the computer. I can message you a seed code if needed. I have a few I'll probably never use. If you already have a key that will start the car you won't need a seed code to simply add another key.
swfla (08-18-23)
#43
Did you ever try putting the old battery in and see if that did anything?? doesn't make sense that putting a new battery in the fob would do this.
Why don't you try going through the registration for a new key...you said the spare didn't do anything right, can't hurt to try. I've only programmed one new key and a card key for mine but I'd be trying everything before spending any amount of money.
There is a key diagnosis in TS smart access but I've never used that function.
#44
I just saw Miket000 already mentioned adding a key.
#45
Can you share with us the Year - Make - Model of the car we are discussing in this thread?
