Replaced Front Air Shocks VGRS Code after 30 miles
Original front air shock assembly replaced at 73K miles with NEW pair of Arnott shocks due to driver side noise over bumps. Local repair garage performed install. Drive perfectly for 20 miles and VSC System & VGRS System errors; local repair garage could NOT clear the error code. Error occured after I tested the "Sport/Comfort and Height controls". Did they forget a key setup or ???? - thanks for ideas.
Are the new shocks air? Even if they aren't, hooking up the original wires and connectors is supposed to eliminate any codes or lights. VGRS is for steering system, nothing to do with shocks. You may have a separate issue. What are the OBD2 code numbers you're getting? Error lights don't tell you what the specific issue is. If the shop you used has Techstream software and they know how to use it, they should be able to help you. If they aren't experienced with Lexus, they may be the problem.
POSSIBLE Fix: Arnott Technical help indicated the air shock assembly does NOT USE the "Sport / Comfort" feature and when I selected the Sport / Comfort selector, a RESISTOR at the top end of the shock possibly shorted and has triggered the error. A FIX is on the way and does not require shock removal to replace the resistor.
swfla (08-23-23)
BTW, how does the Arnott's feel compared to OEM?
aypues (10-02-23)
No codes before install certainly makes the install seem a possible cause. I do hope you find codes afterwards, it'll help. I don't know if there is a module that is shared by both steering and suspension. Looking forward to your resolution and learning from it.
Skid control and variable ratio steering have nothing to do with suspension system as far as I know...why does the strut have a resistor?
swfla (08-23-23)
I don't think it has anything to do with the new air struts, maybe the local garage jacked it up on the steering rack. Maybe it's the battery or alternator...lots of maybe's.
The struts can absolutely screw with VSC since the computers use them as reference for how to control the car based on the level sensors and damping profile.
I'm going to disconnect both front actuators tomorrow and see what codes I get haha.
Gerf's logic is quite good. VSC is more of an instantaneous safety feature. But it could still be possible that it still monitor's it. I don't really know.
That's pretty funny, the air suspension on these cars take almost 5 minutes to go from high to low just sitting still...unless the control units have the ability to see into the future they couldn't keep up unless you're parallel parking on a perfectly level street.
I had to when I replaced my 460s front arms and struts so maybe that's all it is? He needs to scan the thing and tell us exactly what it wants lol
He did drive it 20 miles before an issue came up and then only after he touched ride height switch. This will be an interesting one to follow as I haven't seen any threads about Arnott air shocks installed.
Now I'm wondering if there's something wrong with my car lol.
LOL, I feel your concern. No news is good news in most cases.
Hmm. Breaking any actuator circuit throws C173x dtc in airsus. Live data, Gerf? Can you connect to airsus normally??
Ok, going to pull one from mine to double confirm. Back in a tick.
ADD: According to fsm breaking an actuator circuit will store a code but will not light up 'HEIGHT HI' indicator right away.
ADD2: Yes, dtc sets but no indication on dash. Airsus ecu have no means of communicating malfunctions other than 'HEIGHT HI' lamp (by design). I'm leaning towards unrelated vgrs code at this point. But arnott.. Dude... Stingy pays twice imho. That vgrs code needs to be read now, it's probably still stored there, unless battery was disconnected afterwards.
