2007 Mirror Bugging Out
7th Gear
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/1120x2000/img_8430_7d71b3c2528ff224558b747419126ee24cdc32dd.jpeg)
So the right mirror is shutting on the passenger door glass. When I roll the window down, the mirror closes inside the car as the picture shows. I can’t attach the video for some reason of the mirror closing and opening. It sounds like the motor is having some trouble.
Please take a look at the picture and the description.
If the mirror is in the correct position when extended, it's likely there's a problem in the motor assembly. Especially with the noise you hear. You can find used entire assemblies on eBay cheaper ( under $150) and easier than trying to replace motor only. Be sure the mirror has all the same features as yours. Youtube likely has videos on how to replace.
