6x9 speaker replacement LS600
Just wanted to drop this in for anyone that was a little frustrated looking for replacement speakers. I had the stock ML 6x9 go out in my LS600 b/c the voice coil went bad. I didn't want to buy the new $650 and I went the ebay route and that speaker didn't work. I eventually found an 8ohm PowerBass 6x9, OE-690D. It took some trimming on the stock frame from the old speaker but it fits and sounds great. Crutchfield said it needed to be surface mounted but it works fine. You do need to get the Metra connectors and pay attention to the wiring directions.
Just an fyi be really careful pulling out the window/lock button panel. I snapped mine but was able to superglue and polyurethane it so it looks good again.
Now beware of premature AMP failure down the line..
Replacing a speaker on a proprietary system is not "if it fits" operation. Your ears may not know the difference but, as Boykie stated, it can put undue stress on amp. To be safe, play it at a moderate volume.
Everything I've read says that ML are 8 ohms. So I put in an 8 ohm replacement. The amp will not care. 8 ohms is 8 ohms. If the stock is 12 then I would run into issues if I blast my stereo which I don't do. The crossovers on this car are very low so the 6x9's are rarely engaged with the music I play.
Sounds like you're certain it's OK. I only meant to give you general concern. Never meant to say you're wrong or debate. Lots of threads here as well as well as all the reading I've done indicate what I stated is common enough. Hope you enjoy the speakers.
Fair enough. I'll definitely let people know if I blow my amp. I'm 95% certain I'll be ok lol. I have no problem learning from my mistakes and letting others on the forum learn cheaply
Focal makes replacements for the front and back door speakers. Are you looking to do those or the one on the back shelf.
Just an FYI - while speakers get spec’ed at 4 or 8 ohms, their impedance varies across the frequency spectrum they’re asked to reproduce. Any time you change the speaker, the impedance curve will vary. With that being said, if the speaker is accurately reported as 8 ohms (meaning impedance doesn’t dip super low at any point) you shouldn’t have any problem. But, as others have indicated, there’s not any guarantee the amp will handle the different load.
I think it's reasonable to say that a proprietary sound system (such as ML) has engineered designs with impedance and crossovers that are unique and difficult to reproduce with aftermarket items. This engineered matching is why the system sounds so great. Yes, you can do this. I replaced dash speakers on an ES350 non ML and they sounded better than stock. The mid and low range speakers are more likely to put a load on the amp. Replacing two speakers is less likely to be an issue vs replacing all with aftermarket. In the end, if you like the way it sounds and don't push it too hard, you'll be fine. I do appreciate the sharing of info about aftermarket speakers that sound great and are affordable.
I know focal and these are speced for the car so it’s an easy no brainier. Not expensive better than oem replacements not expensive too. I think it’s a good option for replacements if anyone needs new speakers.
I became curious about this aftermarket speaker thing. On Crutchfield website, 6x9 speakers (including Focal) for a 2013 ML system are rated at or close to 4 ohms impedance. I don't know if this is correct impedance for LS460, just interesting.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1372x620/image001_736051ebdb9cc2b59cbea64b1d03329eb82aa9ad.png)
