Microphone Issues
#31
The second thing, I just had a look at mine a 2013 and it has 2 mic looking ports above your head and I believe the one to the right is a dummy...the one closest to your right ear has a mesh foam filter and mine seems really stiff but I'm not having any issues. That could get plugged somewhat and cause a problem like yours because you say if you yell the recording playbacks are clear. Just spitballing at this point but both are fairly easy tests.
#32
2 other things that I would try, in settings in your menu/settings/phone settings/sound settings I would try that at like midpoint because it states that messing with that can have negative effects on people hearing you...easy test.
The original overhead light assembly/mic screen was clean and so was the replacement overhead light assembly. Given that there was no improvement between the two light assemblies/mics that were installed, it leaves me to believe the issue is something else (software, head unit or wiring).
#33
Many find the Lexus map system more cumbersome than, G Maps, IMaps or even Waze. So, GROM will make that nice for you as well as other apps. When you're installing it (be sure to order the proper adapter cables by year) you'll have the opportunity to get at the connectors. Who knows what you'll find, maybe even green corrosion as well as poor physical connection.
#34
I may have Grom install it...they are only about 30-40 minutes away from me. I haven't decided if it's worth the labor expense or not yet but I am on the group buy list for the hardware. There is also the option of using a mic they supply which I may fall back on if wiring the cars mic through the Vline VL2 box does not fix my mic issue.
PVELEXUSGX
GX - 1st Gen (2003-2009)
09-25-23 10:47 AM
