Aisin AA80e 2-3 cold flare - low fluid?
The cold 2-3 flare our transmissions have on the first trip up through the gears seems to be worse when going uphill. Could it be caused by low fluid level? Has anyone done a transmission fluid change and reduced or eliminated the 2-3 flare?
I've read several threads stating that even 1/2 qt low can produce symptoms. The trans fluid must be at a specific temp when refilling for proper fill. Also, many post about drain and fill trans fixing issues. Next step up is dropping pan, new filter. A bit more work/expense.
Can be caused by incorrect fluid level (too much/too low) and undercharged battery.
If you are close to or over 100k miles, it's time to do a fluid service. Why would your fluid level be incorrect? Do you see signs of leaking? Has the trans fluid ever been serviced? A fluid service is an affordable diagnostic for your concern. Also have battery and charging system checked. Suggest you do it and let us know the outcome. Hope it helps.
cheezbendr
09-30-22 09:10 AM
NewSlang
09-17-20 09:07 PM
