Locked out
10th Gear
Locked out
My battery in my 2008 Lexus 600LS is dead ! I have tried to get in the trunk by using the emergency key in the key slot in the trunk and it won't turn. Under the hood, where is the fuse box located ? I could jump it by using a jump box on the fuse box. What fuse should I hook it up to ?
You might get the key to turn by applying some pressure to the trunk lid while you try the key. Maybe try getting someone to sit on the trunk while you try the key.
Also try opening it by accessing the emergency release via the pass-fhrough door.
