The Saga continues
7th Gear
So I didn't do MAF cleaning I took into the dealer due to dash lights check engine/traction control/messages of having the dealer check VSC and PCS system. Codes that popped for Orielly were P0796 and P2714 pressure control solenoid or stuck off for C & D. I thought this may have been for air suspension sensors but it wasn't it was for transmission and something clicked in my head when I was talking to the dealer and I mentioned the that the transmission was shifting funny after having a leak fixed for transmission fluid cooler. The rep wants to do this and do that and recommend this since I had already cleared the codes I firmly requested simply check the transmission fluid level since you don't make an easy way for us owners to do it so they said they would check all fluids and get back to me. The call came later in the evening there were stored codes for Transmission overheating and the mechanic confirmed with a heat gun test I guess and low and behold the fluid was low. So 600 dollars later hopefully I avoided the catastrophe of blowing up the transmission because I was aware of the maintenance history and skeptical of the aftermarket repair shop topping off transmission fluid correctly after they fixed the cooler leak. Fingers crossed.
Oreillys code scan
Message on dash low trans fluid? Trans overheat
Oreillys code scan
loveslexus
11-14-13 04:07 PM
