Moving from LS430 to LS460 - Battery Questions
The major standby load is the keyless entry system. The keyless entry system is disabled after the car has been locked for 2 weeks. Your owner’s manual explains this.
Dean2 (04-26-24)
A bit of an update to my post above. Have had the LS460 on a battery tender all winter. Car hasn't been driven for about 35 days, prior to unplugging the tender. Took it off two weeks ago as I was going away and didn't want to plugged in while I was gone. Got back, measured the battery voltage, still at 12.67 after 14 days just sitting.
So the good news is, for longer term sits the car must go into a deeper sleep than what I was first measuring. Once it has sat un-driven for a month or so, the draw must drop to nearly nothing as 12.67 is virtually a fully charged battery. If the draw had remained at even 40 Milliamps, it would have drawn it down more than that.
So a battery in good condition, and a car stored in heated indoor storage, no alarm armed, appears to be able to sit for very l;ong periods of time without flattening the battery.
Well try it out and let us know becuase I can't think of a single good reason to lock three doors and leave one open when parking the car for 2 or more weeks.
I read it perfectly right the first time. Does not change my comment one bit. What would be the point of locking just 3 doors. If the car is in secure parking, leave all 4 open for ease of access. If it isn't in secure storage you had better lock all 4.
On top of that, you are giving me attitude after all the work I went to, to post this information in the first place? Ingrate.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Let's keep things polite folks.
Zetascry, your post was not clear what your 'use case' for leaving one door unlocked is. It's a valid question and if you want help on the answer consider answering it. I suspect no one will have ever tried doing that so you're probably on your own to test it out.
